repair bushing shift cable
Old May 16, 2017 | 02:49 PM
mterrell's Avatar
mterrell
2nd Gear
Default repair bushing shift cable
I have removed the shifter but the shift cable want move. What do I need too do in order to get the cable to move?
Old May 16, 2017 | 04:14 PM
Smoken1's Avatar
Smoken1
What cable there are 2 for the A4 trans
Old May 16, 2017 | 05:24 PM
tbrowne's Avatar
tbrowne
There is only one cable. It's attached to the gear selector arm on the trans in the rear and to the shifter linkage in the console. You'll have to jack the rear up high enough to crawl under the car and move the gear selector arm by hand to move the cable. The cable is delicate and will break if bent too much. The gear selector will move at the trans without much effort. You just have the get to it.
Old May 16, 2017 | 06:02 PM
Smoken1's Avatar
Smoken1
There are 2 from the shifter one of them goes up to the ignition switch so it will only start in P or N position
To repair bushing shift cable
