Door Unlock Intermittent Failure
Old May 16, 2017 | 08:30 PM
2ndvett01's Avatar
2ndvett01
Default Door Unlock Intermittent Failure
Problem started when passenger side wouldn't unlocck from inside. Two days later driver side wouldn't unlock with key fob (unlocked with key). I can hear locks trying to unlock when problems occur. The problems have been intermittent for the last few days. Any advice would be appreciated.
Old May 16, 2017 | 09:39 PM
My Vette Life's Avatar
My Vette Life
i get this a lot. My theory is the driver's side door wiring that causing the problems. I haven't tackled it yet since it's not on the priority list.
Old May 17, 2017 | 04:02 AM
2ndvett01's Avatar
2ndvett01
Default Thanks
Lots of info. Will do the checks.
Old May 17, 2017 | 08:09 AM
acuevo's Avatar
acuevo
Originally Posted by 8VETTE7
If the voltage is 12.5 or less then the battery is low or going bad.
i know these cars are sensitive to battery voltage, but 12.5 is still a perfectly acceptable reading. i definitely wouldn't call it low and wouldn't replace a battery based on voltage alone.
Old May 17, 2017 | 10:34 AM
2ndvett01's Avatar
2ndvett01
Default Battery Voltage
Voltage at 12.45V. Is this low enough cause the intermittent problems?
Old May 17, 2017 | 11:39 AM
acuevo's Avatar
acuevo
generally 12.45 would be fine. i'm not sure what the "threshold" would be on our cars though since lower voltage causes so many issues. someone here with greater c5 experience should be able to say for sure though.
Old May 17, 2017 | 11:42 AM
heavymetals's Avatar
heavymetals
I have spare relays for the control module.
Old May 17, 2017 | 06:23 PM
SG Lou's Avatar
SG Lou
I would have the battery fully charged ( should be able to get it to 12.7 or more if the battery is good) and see if it retains the charge by re-measuring the voltage in a few days.
Believe me when I say the electronics in these cars is very fussy on voltage levels. The C5 electronics were designed in the early 1990's and the voltage cut off levels in the technology used is MUCH higher than in the electronics of todays newer cars.............
To Door Unlock Intermittent Failure
