head light problem
Old May 17, 2017 | 12:32 PM
rcdavis2017's Avatar
rcdavis2017
2nd Gear
Default head light problem
2001 driver side out of sync with passenger side. both worked fine when i would turn off lights both close and then driver would pop open again. found drive motor case glue came loose so i pressed it back together glued it and put a 3" hose clamp on it. now they work fine up and down no noise but one is up and one is down. i am not able to figure out where or how to get the arm or motor arm in right spot. do i have another problem or is arm on motor gear not right and if so how do you get it in sync? when i pressed it together the gears had to move like one tooth or so to reline it self . always out of sync sense then.help no hair left to pull out.
