Wheel Sensors
Old 05-21-2017, 09:57 PM
GYM
Cruising
GYM's Avatar
Default Wheel Sensors
If I put 2001 wheels on a 2000 will the TPMS work properly? If not what will have to be done...
Old 05-22-2017, 06:45 AM
GYM
Cruising
GYM's Avatar
Really appreciate the reply....sounds like it will not be an eazy switch
Old 05-22-2017, 09:48 AM
QCVette
QCVette's Avatar
I had the same issues. 8VETTE7 gives the options.
For me I needed new TPMS sensors and did the upgrade to the '01-'04 system. You can cut a lot of expense by shopping for the parts. I got a used RFA receiver, Ebay key fobs, Schrader sensors on a closeout, and a new connector. For me it was under half of what 8Vette7 stated. I did the change out in my garage and it was not very hard or time consuming. I spent an afternoon, but I was going very slow and careful since I had not taken the trim off to get to the RFA receiver before.
Good luck.
Old 05-23-2017, 11:20 AM
Jose2SS
Jose2SS's Avatar
On the C5 I purchased, the past owner changed the wheels and did not installed the TPMS. What is the frequency for a 1999 C5 TPMS sensors?
Old 05-23-2017, 12:06 PM
SG Lou
SG Lou's Avatar
No need to know frequency...when ordering OEM or OEM style aka: Schrader by name, just order for 99 model yr.
Old 05-23-2017, 02:04 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The tire pressure sensors and the FOBs are the same frequency for 97-2000 C5s! In 2001, they changed to the new style tire pressure and FOB sensors. The two systems are NOT compatible.
The 1997-2000 systems work on different frequencies than 2001-2004 systems.
Here are some great articles on the TPMS:
http://www.superchevy.com/how-to/whe...your-corvette/
Old 05-23-2017, 02:50 PM
QCVette
QCVette's Avatar
The '97-'00 do not interchange with the '01-'04 sensors.
However, they are both 315 MHz frequency sensors. I am not sure of the difference, perhaps a different digital signal than what the receiver modules are looking for, but they do not interchange.
To Wheel Sensors
Quick Reply: Wheel Sensors
