Help with code
Old Sep 29, 2002 | 03:57 PM
RogueC5's Avatar
RogueC5
Default Help with code
A1-RDCM / U1064 H
What does this mean? Thanks.
Old Sep 29, 2002 | 04:32 PM
SFVetteman's Avatar
SFVetteman
Default Re: Help with code (RogueC5)
A1 RDCM = right door control module. U1064 is a loss of communication between the PCM and the RDCM and H means it’s history. All the “U” codes are loss of communication codes that seem to pop up occasionally for no apparent reason. They are also triggered, at times, by another code or codes being triggered. If you have no other codes and everything seems to be working properly; I would just do a reset and not worry about it :hat For more info on the codes as well as how to reset, check out this link: https://www.corvetteforum.com/techti...PC%20codes.doc (MS Word document) :)
Old Sep 29, 2002 | 06:35 PM
mozin's Avatar
mozin
Default Re: Help with code (SFVetteman)
Reset, and fo-git-a-bot-it.
Old Sep 29, 2002 | 08:40 PM
RogueC5's Avatar
RogueC5
Thanks.
To Help with code
