Difficulty Shifting M12
Old Jun 8, 2017 | 08:45 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Difficulty Shifting M12
Hi guys, recently I've developed a problem shifting 4-5 and 6-5 gears; all others are by the book. Is this a clutch situation or MGW shifter matter or something else? Your opinions and recommendations welcomed and thanks.
Joe
Old Jun 9, 2017 | 01:10 AM
El original's Avatar
El original
How bad is it, does it grind or lock you out almost entirely? Is it speed related or at any speeds. Just happen or over time?
QUOTE FROM POST WITH SIMILAR ISSUE---This sounds like a reverse lockout solenoid giving you problems. I recently read a post where a gentleman was able to pull the solenoid, clean it up, re-install it and the problems went away. You may want to do some research. Might save you some big bucks.($147- for new solenoid, easy to install)
