Right Rear Flat, now 30psi, sensor going?
Old Sep 30, 2002 | 01:38 PM
gmf's Avatar
gmf
Default Right Rear Flat, now 30psi, sensor going?
Topic says it all. I'm hanging tight to see if it happens again, but I don't like seeing 0 psi when I'm driving down the road! Scared me! :) :eek:
Old Sep 30, 2002 | 04:38 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Default Re: Right Rear Flat, now 30psi, sensor going? (gmf)
happened to me a couple times...might just be a glitch, as mine always resolves. still scary as all heck to see 7psi on the DIC...strangely enough, it's always my rt rear sensor as well
Old Sep 30, 2002 | 06:36 PM
carpe dm's Avatar
carpe dm
Probably just a "transitory".... These cars are a sensor/grounding nightmare; wonderful when it all works, but........ Do a training routine ans see what happens. :rolleyes: :)
[Modified by carpe dm, 4:37 PM 9/30/2002]
Old Sep 30, 2002 | 06:52 PM
SFVetteman's Avatar
SFVetteman
While driving down in southern California a while back when the air temps were as high as 109, my tire monitoring system went nuts when driving at freeway speeds which kicked up the tire pressure above the sensors upper limit. I got service tire monitoring system messages as well as flat tire messages. Sometimes the pressures would read out with xx’s and sometimes 0. When the tire pressures returned to levels that the sensors could read, the warnings went away.
Old Sep 30, 2002 | 07:47 PM
COOL Z06's Avatar
COOL Z06
Default Re: Right Rear Flat, now 30psi, sensor going? (SFVetteman)
...... and on the right rear tire too!
Only happened twice, both times after I stopped, filled with gas and then started moving again. Once I reached freeway speeds and hit the "reset" everything returned to normal.
Old Oct 1, 2002 | 01:06 PM
gmf's Avatar
gmf
Default Re: Right Rear Flat, now 30psi, sensor going? (carpe dm)
Carpe dm,
What is a training routine? :confused:
Old Oct 1, 2002 | 07:03 PM
COOL Z06's Avatar
COOL Z06
Carpe dm, What is a training routine? :confused:
You hand your wife the tire guage and have her check the tire pressure. :D
To Right Rear Flat, now 30psi, sensor going?
