Headlight lowering with hids or leds solved
Old Jun 10, 2017 | 01:34 PM
corvettenoob1's Avatar
corvettenoob1
Default Headlight lowering with hids or leds solved
So I suffered from the infamous lowering issue when it comes to using leds or anyone who has uses hids aswell. You have to lower them after while the high beams were engaged.
Well look no further than vleds.com. I orderd 2 9005/9006 vled6 resistors and once they arrived I went to work installing them. With a flick of the switch in the low beam setting to off, they went down like normal. These things work like a charm, Just about 3" long and 2" wide, they are small and compact and you can hide it easily and not have a big ballast or gold resistor getting hot or smoking.
They cost $15 bucks plus shipping on their website. If you want to get rid of your issue, id buy these now. Heres the link: Order a set. Select 9005/9006 adapter on the bottom where it asks and select 2 for quantity for use for left and right low beams. You wont regret buying these.
http://www.vleds.com/shop-products/v....html?___SID=U
