Where can I find this trim push pin?
I am replacing the weatherstripping that goes over the halo and seal the back side of the targa top when it is installed. There are 4 of these plastic push pins used to install it. Two of them go directly into the body and the other two are installed into the plastic cover that hides the seatbelts. Does anyone know where I can get more of these? I have looked all around including parts diagrams to try and find a part number to no avail. Any help is appreciated.
I just purchased 4 of them as I'm replacing the same weather stripping.
GM 20538173 Weather strip interior trim panel fastener pin retainer xmas tree
http://www.ebay.com/itm/250993328013...%3AMEBIDX%3AIT
jarero (06-15-2017)
SG Lou (06-15-2017)
SG Lou (06-21-2017)
Received 19,308 Likes
'20-'21-'22-'23-'24
Great info - have saved the part number just in case I ever need to buy some.
SG Lou (06-21-2017)
I would have gave you some as I am taking my car apart
Found these: http://www.ebay.com/itm/272759458084...84.m1555.l2649
Thanks!
Thanks!
jarero, where did you get your weatherstripping from?
I need to replace mine as well...
Did you go GM or other like Metro Moulded?
Any tips from your recent install that may help me before I start?
(ordered the fasteners already)
Thanks...
Thanks...
