T56 transmission bench testing (rebuild)
Old Jun 15, 2017 | 11:45 PM
conradb's Avatar
conradb
Default T56 transmission bench testing (rebuild)
Is there any company in the so-cal area that can do bench testing of my transmission I'm rebuilding? I'm worried about the shim tolerances. I'm using a dial indicator to measure the play and trying to properly shim it, but I'd rather make sure everything is solid before I go through all the effort of reassembling the car's driveline. Thanks!
Old Jun 15, 2017 | 11:46 PM
conradb's Avatar
conradb
Also, on the main shaft, I get no in-and-out play anymore after shimming, but I get a slight side-to-side wobble. Is that normal? The dial indicator shows no in-and-out play.
Old Jun 16, 2017 | 01:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
Call Ron at TRC transmission in Chatsworth, did my T56 up and all others for the last 20 yrs nothing has broken yet. 818 882 0082
Old Jun 16, 2017 | 01:44 AM
conradb's Avatar
conradb
That's not too far. Maybe I'll give them a ring tomorrow. I'm located in Long Beach.
Anyone know anyone else that may be closer to LB?
To T56 transmission bench testing (rebuild)
