C6 ZO6 brakes
Old Jun 18, 2017 | 02:52 PM
chasb4570's Avatar
chasb4570
Default C6 ZO6 brakes
Kind of thinking on doing this upgrade. My question is how much more clearance is needed in reference to the back of the wheels. I have aftermarket IConZ 19" on all four corners. 2" lip in front and 3" in rear. The center section from the hub to the rim curves inward. Regarding the raised rib in the stock caliper casting, I can put my pinkie between the rib and back of wheel. About 3/16" between rib and back of rear wheel. Any hope of doing this without spacers? Have 275/30's on the front and 305/30's on rear. The wheel offset puts the outside of the tire right at the edge of the fender lip, no protrusion past the fender.
Thanks for any info.
Chas
Old Jun 18, 2017 | 03:19 PM
oneandgone's Avatar
oneandgone
You're probably going to be best off calling your wheel manufacturer and asking if they will clear those brakes. I have been hunting for a multi piece, fat lipped wheel that will clear and have not had much luck. My guess is that with your lip and spoke design they will not clear the front caliper.
Here is another recent thread where there was some discussion on this...
https://www.corvetteforum.com/forums...06-brakes.html
Old Jun 19, 2017 | 07:52 PM
marc a's Avatar
marc a
Can't remember where I got this template but it works.
File Type: pdf
Old Jun 20, 2017 | 04:20 PM
FASTFATBOY's Avatar
FASTFATBOY
I can lock up hot slicks with the stock brakes, put a good pads and rotors on the car is all you need.
Unless it's car show looker reasons
To C6 ZO6 brakes
