Looking to see if anybody knows the wire gauge for ground splice pack SP122. Looking to replace with a better connector and need wire size for the pins.
Wire gauges are listed on the schematics in mm squared cross-sectional area. If you do a search online you can find calculators and conversion charts to convert AWG to metric.
The manual shows SP122 with seven wires so I'm not sure what that is in your picture. I only see 5 wires.
In any case th manual shows SP122 pins A and C as .35 which is roughly 22AWG. B,E,F,J, are .8 or 18 AWG and D is 3 which would be 12AWG.
Found this in the manual for some splice connectors.
I see that also sell a pro kit ( for 3x the price) that has a selection of contacts that will do 22-10 AWG so if you have wires larger than 16AWG, that might be useful.
METRI-PACK 280 KIT SEALED BUSS SPLICE PRO KIT 22-10 GA. BUSS BAR
INCLUDES 12094430 REMOVAL TOOL
Yea, that's the one I purchased myself
Will update with pictures once I get it installed on car.
