Code P0343 C
Old Sep 30, 2002 | 09:22 PM
fairway's Avatar
fairway
Default Code P0343 C
Does anyone know is this code means P0343 the car is hard to start sometimes you have to turn the key like two or three times before it will start it just started doing this and the other code is a P1571 both on PCM
Old Sep 30, 2002 | 09:45 PM
kwik8racr's Avatar
kwik8racr
Default Re: Code P0343 C (fairway)
PO343 = CMP sensor high voltage - B
P1571 = ASR desired torque - C
Old Sep 30, 2002 | 09:49 PM
fairway's Avatar
fairway
What is the cause.
Old Sep 30, 2002 | 09:58 PM
belair55's Avatar
belair55
If I'm not mistaken P1571 is a '97 only code for normal operation and it is set continuously. Someone please correct me if I'm wrong.
Old Sep 30, 2002 | 10:29 PM
fairway's Avatar
fairway
Yes it is a 97 wounder why it is hard to start not all the time just somtime.
Old Oct 1, 2002 | 02:55 AM
Richin Chicago's Avatar
Richin Chicago
This is a code indicating the cam positon sensor, or assciated cabling and connections is intermittent or failed. I'm not sure how the PCM uses this information but it can't be good to be losing it.
Old Oct 2, 2002 | 12:46 AM
fairway's Avatar
fairway
Anyone else :confused:
Old Oct 2, 2002 | 11:33 AM
best_vette_yet's Avatar
best_vette_yet
Your starting problem has to do with your P0343 code. That code is for the cam position sensor. If you only had a crank postion sensor it would not know if you were on compression stroke or exhaust stroke. The Cam position sensor tells the computer which stroke your on. For your coils to know when to fire the car needs to know when you are comming up on the compression stroke.
Your computer should store freeze frame data on this sensor. You will need a "auto tap" or "tech II" to read the data.
Good Luck
To Code P0343 C
