CAGS defeat switch
Old Oct 1, 2002 | 01:34 AM
openyd's Avatar
openyd
Default CAGS defeat switch
Where is the wire harness located under the car? Do you need to place the car on a lift to access the harness?
Old Oct 1, 2002 | 01:50 AM
gmblack3's Avatar
gmblack3
Default Re: CAGS defeat switch (openyd)
Look at the last few pics here:
http://www.picturetrail.com/gmblack3/647207
Old Oct 1, 2002 | 01:59 AM
openyd's Avatar
openyd
Default Re: CAGS defeat switch (gmblack3)
Thyanks for the info--very helpful pics.
Old Oct 1, 2002 | 10:50 AM
Mark VerMurlen's Avatar
Mark VerMurlen
You need to be able to get underneath the car to the transmission in the back. You can do this with ramps or on jack stands. You should then be able to reach up alongside the transmission to disconnect the wires and plug them with the supplied kit. Be sure to get the right wires. If you find that the CAGS is still functioning afterward, you didn't disconnect the right wires.
- Mark
To CAGS defeat switch
