Pop-up headlight issue
Old Jun 25, 2017 | 09:58 PM
FR CPE 99's Avatar
FR CPE 99
Default Pop-up headlight issue
New C5 owner (first Vette) and new to this forum. Purchased a 99 FRC from the original owner with 35K miles on the clock. Pristine maintenance over the years. Both headlights pop up and close perfectly fine when the engine is off, no funny noises or grinding; however, when the car is running, they will only open about 10% of the time. I've seen a lot posted on the lights but nothing exactly like this. If it were the switch, I would think it wouldn't matter if the engine is running or not. Any ideas would be appreciated! Thanks.
Old Jun 26, 2017 | 07:13 AM
FR CPE 99's Avatar
FR CPE 99
Thanks for the quick response and details. I'll give it a look to see if there is any corrosion or if the ground is loose. Appreciate the help!
Old Jul 16, 2017 | 10:33 AM
FR CPE 99's Avatar
FR CPE 99
I followed the schematics and found the ground and splitter pack. Not a drop of corrosion on the screw or inside the plug. The motors work and sound great when the car is not running but once in a while if I turn the light switch very quickly, I can get the lights to pop up when the car is running. Wondering now if there is some sort of short coming back to the stalk?
Old Jul 23, 2017 | 10:45 AM
FR CPE 99's Avatar
FR CPE 99
Default Problem fixed
Sometimes it's the easiest solution. Tightened the battery terminals and the lights function normally. It also solved the flickering radio issue. Thanks for the help.
Old Jul 24, 2017 | 07:20 AM
Mickeyrx70's Avatar
Mickeyrx70
Thanks for letting us know the solution.
To Pop-up headlight issue
