Swapping Odometer module in Cluster, How?
So, right now I have a Z06 cluster painted red with HUD installed in my 98 Corvette! (which all should know is not possible as Z06 did not come out yet and its a vert to top it off). My problem is the odometer reading and I was hoping somewhere there was a discussion on swapping what ever unit that is in on the old cluster. I really like the style of the Z06 cluster. Does anybody know what unit is used on the cluster for holding odometer reading and has anybody tried this?
Second choice is if anybody knows specifically where I can send the cluster in to get the correct reading loaded into the Z06 cluster.
Not sure what you are asking exactly. The Odometer reading displays in the DIC which is the small display below and between the Tach and Speedo. You can display ODO miles by scrolling through with the buttons to the left of the instrument cluster, specifically the one that says "TRIP". If this display is blank, then you have bigger problems, like the switch cluster bad and a few other possible causes.
The ODO miles are logged by your BCM.
the stealership can make the handshake between the BCM and the IPC for ODO reading,, provided there are no comm problems. If your DIC is messaging, clear your codes before going to the stealership. Someone else may have a method for making this handshake, perhaps others will chime in and tell you how to do it w/o going through the pain of seeing a dealer.
After consideration and looking at my original, all I have to do is solder a connector on top and my HUD will work with the old cluster and I will have correct milage. I have a Carbon Fiber red/black outside piece where the switches go and ordered some red colored rings to install around the gages. After looking at what I have I think it is going to look better than the all red Z06 cluster (more sophisticated less kiddie look. Will post pics when done. I love it when a plan goes together and works out. Just got to practice on my solder skills, used to be NASA certified so I am not to worried!
The BCM does not have the Odometer data it is stored somewhere in the cluster unit. I know this because when I installed the Z06 cluster from the original the milage shifted to what the other car had. Do you know which unit on the IPC holds this data? I want to see if it is feasible to install my old one in the Z06 IPC.
This is probably an easier way to accomplish what you want
