AIR delete question
Old Jun 30, 2017 | 12:33 PM
JVOG's Avatar
JVOG
7th Gear
Default AIR delete question
Ok so I've removed the air pump inside the front bumper. What I'm wondering now is if I have to remove the intake manifold to delete the piping behind it or can I just cut and plug the piping or is plugging it even necessary?
Old Jun 30, 2017 | 12:40 PM
grantv's Avatar
grantv
If you've removed the piping from both sides the piece back there is doing nothing. No need to plug it. You do need to plug the vacuum tube where the pump was tho...
Old Jun 30, 2017 | 02:26 PM
JVOG's Avatar
JVOG
7th Gear
The vacuum tube, as in the tube that connects to the air lid? I've done that, just plugged it at the air lid. Just wasn't sure about any of the other piping coming from the other tube where the pump was. Right now I just have one tube on each side next to each manifold. My plan was to just cut each one close to the firewall to avoid pulling the intake manifold. I'm assuming that would be fine?
Old Jun 30, 2017 | 03:25 PM
bravo29's Avatar
bravo29
People buy a breather filter for it and place it in the hole or cap it off on the lid. That is what we did on the Fbody cars.
Old Jul 1, 2017 | 02:01 AM
Carl Timonen's Avatar
Carl Timonen
The vacuum tube is the small line that comes from below the battery. If it's not plugged, you lose control of you hvac vents and create a manifold vacuum leak.
Old Jul 1, 2017 | 09:23 AM
JVOG's Avatar
JVOG
7th Gear
The only lines I see are the 2 that come from the pump, one to the air lid and the one that goes to the driver side exhaust manifold and then to behind the intake manifold then to the passenger side exhaust manifold
Old Jul 1, 2017 | 10:23 AM
huesmann's Avatar
huesmann
The vac line technically goes to the solenoid/valve.
Stealing this pic from Bill Curlee, I circled the vac connection in red:
Old Jul 1, 2017 | 10:35 AM
JVOG's Avatar
JVOG
7th Gear
​​​​​​Yeah I didn't have that on mine. My pump actually looks different also
Old Jul 1, 2017 | 12:40 PM
grantv's Avatar
grantv
Never seen one like that. Your car is a C5?
Old Jul 1, 2017 | 12:50 PM
JVOG's Avatar
JVOG
7th Gear
Yep 98 c5
Old Jul 1, 2017 | 12:53 PM
JVOG's Avatar
JVOG
7th Gear
My AC vents seem to be working fine though. I can't really say if it's affecting idle or not because I just did a cam swap and am awaiting a tune so it struggles to stay running as it is right now
Old Jul 1, 2017 | 07:20 PM
grantv's Avatar
grantv
Looks like yours is not vacuum accuated, you're good to go.
Old Jul 1, 2017 | 07:22 PM
grantv's Avatar
grantv
The vacuum tube, as in the tube that connects to the air lid? I've done that, just plugged it at the air lid....My plan was to just cut each one close to the firewall to avoid pulling the intake manifold. I'm assuming that would be fine?
Fine, exactly what I did, not worth removing the intake manifold at the time (and that was 3-4 years ago).
Old Jul 1, 2017 | 11:47 PM
JVOG's Avatar
JVOG
7th Gear
Perfect, that's what I was hoping for. When I decide to throw a set of heads on I can delete the rest of it when I take off the manifold. Just trying to avoid taking it off just for that. Thanks guys
Old Jul 2, 2017 | 02:56 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
You should be OK However typically when removing the AIR pump and blocking off the AIR tubes on the exhaust manifolds you will get a DTC code---Which then would require tuning to turn the AIR pump function in your ECM OFF as well as deleting all the AIR codes permanently
Old Jul 2, 2017 | 01:11 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Any guidance for those with a tech 2 on how to delete those permanently? Or can it be done with efi live tuner maybe?
To AIR delete question
