Electrical garu?
Old Jul 2, 2017 | 03:15 PM
royal flush's Avatar
royal flush
Default Electrical garu?
I have 2001 z06--every about 25 starts--put key in- go to on--dash lights flicker and fuel pump kicks in--takes about 3-4 seconds-total time-turn key to start--fires right up?? NO codes--battery cables tight--grounds tight--maybe ignition switch?
Old Jul 2, 2017 | 04:25 PM
royal flush
Originally Posted by 8VETTE7
Might be ignition switch, might be starter solenoid getting lazy and if you have headers might be the connections at the starter solenoid. Common issue with headers is that the wires at the starter solenoid get fried and/or the bolt that hold the positive battery cable onto the solenoid loosens up due to the extremes of heat cycles.
Thx for the reply--no headers stock car with 10,000 miles--seems like the car acts up after driven and its hot here in vegas--always fires right up first thing in am--Also when i do put key in and go all the way right to start car--about every 30 starts or so it clicks like no juice--i take key out -put in and starts right up--
Old Jul 2, 2017 | 04:47 PM
royal flush
Click like in a relay making a click sound??
Or click like in the starter solenoid failing to engage the flywheel?
Or some other click???
I would describe like a hard bump--something not connecting--everything dead--take key out reinsert--car fires right up--not like a relay
Old Jul 2, 2017 | 05:17 PM
royal flush
Measure the voltage across the battery posts with a digital multi meter. Needs to be 12.7 to 12.9 volts or more if the battery is fully charged. Don't bother with the dash gauge readings. They report the state of health of the charging system and NOT the state of health of the battery. With engine running you are seeing approximately the output voltage of the alternator. With engine OFF and key ON the reading is pretty meaningless as there are many electrical circuits in the C5 that place a load on the battery with key ON.
I just took a reading yesterday am--12.73 volts and battery has been load tested--everything good---if you had to guess what would you say could likely be the problem?
Old Jul 2, 2017 | 08:03 PM
royal flush
Also why wouldnt it start like ive explained all the time and not just once in awhile?
Old Jul 3, 2017 | 02:15 AM
REKCUF's Avatar
REKCUF
2016 C5 of Year Finalist
Old Jul 3, 2017 | 04:14 PM
royal flush
Thx 8vette7--im sure your right about starter sol. or ign switch--anyway i can live with it as i know it starts everytime the second time when it acts up--just another c5 gremlin-
Old Jul 19, 2017 | 10:15 AM
royal flush
To follow uo and let everyone know results--it was the Ignition Switch--some black spots ect on the switch connections--new ac delco switch-everything good to go-
Old Jul 19, 2017 | 11:15 AM
royal flush
Thanks for updating your problem resolution. May well help some other Forum member with similar symptoms.
I wish other members would get back to what resolved there problem--you helo them and there -gone
To Electrical garu?
