DIY: C5 Corvette Steering Wheel Removal and Aftermarket Install
Way to be persistent. Yea a proper steering wheel puller makes the job much easier.
I'm curious why you installed the hub adapter upside down and offset. Is that because the square hole in the adapter lines up better with the air bag wire? Alternatively you could run the horn wire through the square hole and drill another hole for the airbag wires. Then you don't need the offset adapter.
Does your clock spring still work?
Love those seats. What are they?
Nice car. Looks great. I have R888s on my car. Very good tire. 4 (twisty) track days so far. Lots of grip. They don't talk to me as much as the Pirelli Corsas though.
Yup, that works and feels the same not that there's anything much different to feel if we are talking about the clock spring for the turn signal. I don't know much what it does but I do know it's crucial to the blinkers.
Thanks, they are like some original knock off Recaro SRD seats I scored super cheap from this cool guy on craigslist. They are slightly faded though, do you think I should do a quick and light one over with some of that fabric spray paint to darken it up a bit to match the steering wheel a bit better or just leave it alone?
What I mean to say is if the hub adapter is positioned "right side up" the square hole is at 11 o'clock. You have it a 6 o'clock. If you were to install at 11 o'clock you could put the horn wire through the square hole and drill another hole for the airbag wires. I have install this hub adapter on a dodge so I am familiar with it. In any case I am about to do the same on my c5z. We'll see how it goes. Thanks for your video. It has been useful.
Yes. That is what I meant. Thanks.
I do think they would look better if darker. But personally, I would worry about getting an even coat and screwing it up. Awesome seats. I want.
Oh that's cool, what steering wheel are you going with? Quick release or nah? If so, which one?
Yeah, that is exactly why I'm on the fence about it...
Thanks for the kind words. I'm just glad I'm able to help someone out here since you guys are always helping me!
You have the hub adapter on in the wrong position. It is marked with a dot at the top. As mentioned above the square hole is for the horn wire. If you reposition the hub adapter correctly you would not need the spacer/adapter. As for the clock spring you can take it off the hub and zip tie it underneath the knee bolster. Its only function is for the airbag wiring. Its held on with a c clip. You don't need to cut the wire or anything. Then stick a 2.2 ohm resistor into the leads that plugged into the airbag if you want to get rid of the airbag light. ........On the other hand it looks like you got it going. And if you like what you see then that works too.
bthomas (06-12-2019)
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Thanks for posting the video, as it will help others. As noted by others the placement of the hub adapter, if positioned with the square hole at 11 o’clock and used for the horn wires (drilling another hole for the air-bag wires) could make the spacer unneeded. I used the same hub and quick disconnect when installing my Momo wheel and drilled the hole for the air-bag wires as well as used the resistor to eliminate the air-bag light. Your set up looks good and as long as it works is all good.
Here are the pieces I used:
MOMO EAGLE Steering Wheel Leather 350mm 13.8" EAG35BK0S
NRG Steering Wheel Short Hub Adapter for CORVETTE CAMARO FIREBIRD Z28 TRANSAM SRK-170H
NRG BALL LOCK QUICK RELEASE HUB STEERING WHEEL HUB NRG SRK-200CF CARBON FIBER
CHEVROLET Compatible Airbag Simulator Resistor Disconnect Kit - DIAGNOSTIC TOOL (to eliminate the Air Bag warning light from staying on)
NRG CARBON FIBER STEERING WHEEL HORN BUTTON RING REPLACEMENT 6 BOLT PATTERN MOMO
MOMO Horn Button Large Blank No Logo (got this along with the carbon fiber replacement ring to not have the MOMO logo on the horn button unfortunately I think they are no longer made)
On your video above, the picture before starting the video, look at the hub adapter. As positioned in that picture it is exactly up side down. Rotate it 180 degrees and you will have what we are trying to say.
Also the NRG graphic is visible in the pic. That graphic should be on the top not the bottom.
Just some knockoff Recaro Speed seats I scored for $80 on Craigslist. The were a B!*CH to fit though... I had to literally ratchet strap the bottom bolsters while I bolted them in, it was nuts. They fit great now that they are in though, door closes fine, seatbelt fits too.
Thanks!
Well, because I couldn't find anything not ghey that is royalty free. I tried to put it low enough to where you could barely hear it.
If anyone knows some good royalty free background music definitely let me know.
I usually use low background music to fill in the awkward silences. That's just what I prefer though. I kinda rushed the upload cause I was tired of listening to such shitty royalty free music so I just picked the best I could find. I kinda liked it but I understand not everyone is crazy for EDM or has different music tastes.
