fuel filter
Old Jul 12, 2017 | 05:38 AM
romandian's Avatar
romandian
Default fuel filter
what micron rating does the stock fuel filter have?
Old Jul 12, 2017 | 10:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
What year C-5. There are a couple of different filters used, depending on the year of the car.
Old Jul 12, 2017 | 01:32 PM
romandian's Avatar
romandian
its a 99 returnless.
question is what aftermarket filter to get. do i need 10 micron?
Old Jul 12, 2017 | 05:44 PM
leadfoot4's Avatar
leadfoot4
I think that whatever AC Delco or Wix filter is recommended for your car, will be more than adequate....
Old Jul 12, 2017 | 06:01 PM
feeder82's Avatar
feeder82
AC Delco GF822, for the win, seen a few guys having problems with off brand filters
Old Jul 12, 2017 | 06:33 PM
leadfoot4's Avatar
leadfoot4
FWIW, I got curious. Wix lists their filter at 5 microns.
Old Jul 12, 2017 | 11:49 PM
romandian's Avatar
romandian
i do, but in this case im getting something like a holley 165-552. they come in 10 - 150 micron, i believe. some less expensive ones are 30 micron, for example. so, what do i need for a filter after the pump?
Old Jul 13, 2017 | 07:48 AM
leadfoot4's Avatar
leadfoot4
I'm trying hard not to be sarcastic, but if you're truly looking for meaningful information (which there is a LOT of, on this forum), it would be helpful if you tell us what you're trying to accomplish, up front, instead of in little bits and pieces.
Your initial question makes it look like you're just wanting to know the filtering capability of an OE fuel filter, not that you're designing an entire fuel system upgrade.....
Old Jul 13, 2017 | 09:34 AM
romandian's Avatar
romandian
if somebody can answer the original question, that would be great.
alternative question: what kind of filtering do fuel injectors need?
(you know, the world is getting more and more complicated. there used to be filters and prefilters. that was it. now i have to deside among several alternatives. its just like when i started smoking there was one kind of marlboro. now they make 6 variations of marlboro red.)
Old Jul 13, 2017 | 03:36 PM
feeder82's Avatar
feeder82
what micron rating does the stock fuel filter have? The factory wix or acdelco are rated at least 5 micron
Are you aware the fuel pressure regulator is built in to the factory fuel filter?
Old Jul 13, 2017 | 08:05 PM
Spill8c5's Avatar
Spill8c5
Cruising
heres what you want:
Amazon Amazon
Putting mine in tomorrow, same specs, half the price as GM part number
Old Jul 13, 2017 | 08:07 PM
JacobVrrm123's Avatar
JacobVrrm123
Go with a Wix replacement filter.
Old Jul 14, 2017 | 06:40 PM
StingrayRebel's Avatar
StingrayRebel
are you building a fuel system or running a stock type setup and what pump(s)?... at one point I was running a 255 in tank pump with the sock pre-filter and stock post filter and an a1000 external with 100 micron pre and 10 micron post filters... now I have 2 walbro 450s in the tank with sock pre filters and a single 10 micron post filter... from what I understand you want a higher number micron pre filter and a smaller number post filter... surface area and inlet/outlet size are also things to consider
Old Jul 15, 2017 | 04:21 AM
romandian's Avatar
romandian
yes, im adding an inline pump to the 255 and my "research" shows, that oem use filters even finer than 10 micron, as feeder pointed out. so im going with this:
https://www.summitracing.com/int/par...-552/overview/
this is also a lot of filter for the money, but 3/4 npt is a bit hard to connect to:
https://www.summitracing.com/int/par...4003/overview/
i wonder why they make is so big.
To fuel filter
