What is "normal" operating temp for the A4 auto?
Just drove 1500 miles in my 03 with outside temps in the 80-94 degree F and noted that the DIC showed the A4 at 225-239.
Thanks in advance,
Jim
When I had a 160* TStat it ran even lower - 175 ish on the highway (in lockup)
You prob need to give some TLC to your cooling system... Coolant, Clean debris from
radiator & condensor..
Also, the fluid & Filter in the Trans may be in need of changing too.
These cars came with Dex III from the factory, so your temps are
not great for this fluid. The newer Dex VI can take more heat and is compatible with
the older dex III.
Out on the highway, the temp on my A4 equipped car is normally in the 185-200 range. As mentioned, check to see if your radiator area is a bit clogged up.
In the last month, I had the hoses, belts, thermostat (180), and coolant replaced as well as having the radiator pressure tested at a well-respected radiator shop with all GM parts.
I asked if they burped the cooling system to remove air and they assured me they did.
I had the trans fluid level checked by a GM dealer just after the above work.
I will recheck the radiator for blockage, but my water temps seem OK in hot weather and I personally cleaned the radiator and AC condenser just last year and at that time both were very clean. The fans seem to be working correctly.
So I am still puzzled.......................
I did have an issue arise last week before the trip that I have been consulting with Bill Curlee about where first I got a
DTC B2795 Suspension Control Select Switch Circuit Malfunction code.
I had been working on some iPod wiring under the console and knicked a couple of wires. After checking all the wires running from under the dash to under the console and taping the two nicked wires the B2795 code went away but was replaced by:
C1284 Lateral Accelerometer Circuit
C1287 Steering Position Sensor Circuit
and the Traction control warning sign stays on in the dash cluster. All attempts to find the cause of this have been unsuccessful to date.
So perhaps this is what is causing the high trans temps???? The TC button still seems to function showing TC ON or OFF on the DIC.
Help would be greatly appreciated !!!!!!!
Thanks,
Jim
I also noted trans temps from a cold start to the end of a 2-hour errand run which involved in town stop and go as well as freeway up to 60 mph.
Outside temps ranged from 70 -75 degrees.
10:50am: Cold start showed Trans temp at 81 after sitting in the garage all night.
11:00: Trans was 115
11:06: Trans was 162, coolant was 201
11:09: Trans was 172, coolant was 201
11:15: Trans was 180, coolant was 203
11:19: Trans was 187, coolant was 205
11:32: Trans was 199, coolant was 205
11:37: Trans was 201, coolant was 207
11:48: Trans was 205, coolant was 208
11:54: Trans was 212, coolant was 208
Comments and advice are most welcome,
Jim
Will do,
What should or shouldn't happen when I use my left foot to depress the brake pedal enough for the brake lights to come on?
Jim
I just lightly depressed the brake pedal as you suggested. Not enough to feel the calipers grabbing the rotors. The engine does not seem to have a misfire and being too cold is out.
Would the brake switch be located by the pedal arm?
http://www.zip-corvette.com/97-04-br...al-switch.html
Is there no code set for a failing or stuck brake switch?
Just trying to eliminate possible causes before I install an auxiliary trans cooler.
Thanks again,
Jim
just take it to an independent transmission shop and have them test drive it..
IT's just a 4l60E, just moved back a bit !!
Your temps are too hot. Your coolant temps are normal , so I believe you have
a trans issue. Fix it before it causes more damage if possible
