Traction Control System service
Old Jul 25, 2017 | 03:53 PM
Stshooter's Avatar
Stshooter
Navigator
Default Traction Control System service
Dear sirs, I was driving along when my C5 stopped running, the information display was Traction Control Service. It also indicated low power. The engine had trouble running and would stop. I tried to start it several times and it would run very rough then quit. After a few minutes It started normal power and I drove it home. What do I do to correct this problem? This is the second time this has happened but the first time I was in a heavy rainstorm and thought it was flooded. Today there was no rain. I am hesitant to drive the car until I find a solution. Thanks for your response. Alan Trueblood
Old Jul 25, 2017 | 04:01 PM
Smoken1's Avatar
Smoken1
Have you used the DIC to see what codes are set?
Old Jul 25, 2017 | 04:19 PM
Stshooter's Avatar
Stshooter
Navigator
I am not familiar with the DIC. How would I check the codes. Thanks for your response. AT
Old Jul 25, 2017 | 04:29 PM
Smoken1's Avatar
Smoken1
Old Jul 25, 2017 | 05:27 PM
Stshooter's Avatar
Stshooter
Navigator
Originally Posted by Smoken1
Thanks, I was not aware of this feature. I will clear the codes shown. I appreciate your information. AT
Old Jul 25, 2017 | 05:40 PM
coia96vette's Avatar
coia96vette
Before you clear them write them down. Clear them then drive the car for a good amount of time and pull the codes again BEFORE you shut off the car. Those will be the codes you will want to fix.
To Traction Control System service
