When do your radiator fans switch on?
Old Oct 3, 2002 | 05:40 AM
larrysb's Avatar
larrysb
Default When do your radiator fans switch on?
I'm noticing that sitting at idle for a while my coolant temps seem to rise pretty high (~220 deg) yet the fans don't seem to activate on my new car. What temperature do your fans come on?
Old Oct 3, 2002 | 05:42 AM
Ilovetorque's Avatar
Ilovetorque
Default Re: When do your radiator fans switch on? (larrysb)
Whenever you run the A/C the fans come on. If you're not already, turn the A/C on and your car might cool down a bit.
Old Oct 3, 2002 | 11:24 AM
scool93535's Avatar
scool93535
The setting can be modified in the PCM using LS1edit or similar tool. I think the factory setting with out the A/C is 229. :cheers:
Old Oct 3, 2002 | 11:45 AM
Patches's Avatar
Patches
I'd like to know at what temperatures people here have typically been programming their fans to come on at. I'm fixin' to reprogram and would like an idea of what folks are running at.
:cheers:
Old Oct 3, 2002 | 05:22 PM
WonderBoy's Avatar
WonderBoy
Mine come on at 194.
Old Oct 3, 2002 | 06:07 PM
JR-CRUZN-C5's Avatar
JR-CRUZN-C5
Buy a Vinci Hi-Performance fan controler and you can set the fans to come on at almost any temp. with a small screw driver. It's just as easy as that!
JR :yesnod:
To When do your radiator fans switch on?
