Tonneau cover on vert wont release electrically
Old Oct 3, 2002 | 02:50 PM
RockeVette95's Avatar
RockeVette95
Default Tonneau cover on vert wont release electrically
checked fuse????
Old Oct 3, 2002 | 03:21 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: Tonneau cover on vert wont release electrically (RockeVette95)
There's a manual release cable between the seats behind the waterfall if all else fails. :)
Old Oct 3, 2002 | 03:52 PM
spicoli25's Avatar
spicoli25
I had the same problem on my new 2002 convertible. This is my first convertible Vette. I realized that when I opened the trunk with the power button this would not allow you to use your power tonneau button. I used the manual pull string. When I pulled the tonneau up maually it rubs on the rear end of the opened trunk cover. Be careful I learned my lesson without any damage. Once you close the trunk the button will work. When you hit the tonneau cover button the power windows go down and the tonneau pops up. Hope this helps your problem.
Old Oct 3, 2002 | 04:13 PM
RockeVette95
Default Re: Tonneau cover on vert wont release electrically (spicoli25)
Made sure the trunk was shut still no workey!!!!
Old Oct 3, 2002 | 05:20 PM
THRAP 42's Avatar
THRAP 42
Rocke,
If the fuse is good - two more things to check, wiring and then the switch. Once the tonneau is up check the wiring at the switch and then down the cover to where it plugs into the harness, could have come loose. If all that looks good, short the wires together and listen if the mechanism works to release the cover. If that checks out - bad switch. If neither of those check out get a volt meter and start checking for voltage from the switch back. Has to be an open somewhere if the plugs are plugged and shorting the wires don't work. Oh, just thought of another one, make sure the switch on the trunk lid is being fully depressed, if that is open that could be your problem.
Good luck.
later,
Old Oct 3, 2002 | 05:42 PM
PaceThis's Avatar
PaceThis
Default Re: Tonneau cover on vert wont release electrically (THRAP 42)
I presume everything else works at the current moment?
Old Oct 3, 2002 | 06:57 PM
tscales's Avatar
tscales
St. Jude Donor '07
If the tonneau is rubbing, it is not adjusted properly. This is quite common and most dealers don't have trim guys that either CAN fix it or CARE ENOUGH to fix it.
Mine did and it doesn't rub. The is a particular problem on 2001+ cars because the top is thicker.
Tom
Old Oct 3, 2002 | 07:49 PM
jeanlucpicard's Avatar
jeanlucpicard
Make sure the emergency brake is set. The tonneau latch will not release until the emergency brake is set.
Good luck :D :seeya :cheers:
Old Oct 3, 2002 | 08:02 PM
tscales's Avatar
tscales
St. Jude Donor '07
Default Re: Tonneau cover on vert wont release electrically (jeanlucpicard)
Is that just on M6 cars? I'm pretty sure mine will. I'll have to try it.
Tom
Old Oct 4, 2002 | 12:46 AM
spicoli25's Avatar
spicoli25
Default Re: Tonneau cover on vert wont release electrically (tscales)
On my 2002 it doesnt matter about the emergency brake. Mine is an auto. Maybe on 6spd's it makes a difference.
Jeff
Old Oct 4, 2002 | 08:46 AM
stevenll's Avatar
stevenll
The emergency brake does NOT have to be set to release the tonneau. Sounds like you have a fuse, wiring or switch problem. I'd start with the switch & make sure the wires are firmly seated. Then check the fuse.
If those were ok, I'd head to the dealer to get it fixed.
Old Oct 4, 2002 | 02:24 PM
lotzahp's Avatar
lotzahp
sounds like you have some good suggestions for troubleshooting. Some info you may find helpful along the way:
1)the yellow tonneau switch wires directly to the BCM
2)the BCM verifies that the alarm is DISARMED and the trunk is CLOSED
3)if they BOTH are, the BCM turns on the relay to pulse the release solenoid
4)that relay has a fuse
5)the BCM also issues commands to the DCM's to lower both windows
To Tonneau cover on vert wont release electrically
