Are these Really 02 LS6 Heads?
Oct 3, 2002 | 05:11 PM
Oct 3, 2002 | 05:42 PM
Cruise-In II Veteran
Cruise-In III Veteran
Re: Are these Really 02 LS6 Heads? (Closer_2001)
01 and 02 heads are the same castings. 243
Telling whether they are 02's with the sodium filled valves I am not sure.
I have a set of early production 01 Z06 heads that have blue springs. But I think they changed the color later in 01.
Oct 3, 2002 | 05:44 PM
They should have a part number on them which is different from the casting number...
Oct 3, 2002 | 05:51 PM
Re: Are these Really 02 LS6 Heads? (kewlbrz)
2002 heads have yellow valve springs. 2001 springs were blue.
Oct 3, 2002 | 09:31 PM
Shawn,
Look at the picture...do the ports look correct?
Oct 3, 2002 | 09:42 PM
From the photo angle the ports look wrong. The D port should look just like this D.
Oct 3, 2002 | 09:48 PM
I examine Ls6 heads at car shows to see what the head markings were. 2001/2002 Ls6 heads were marked 243 on the heads, at the front , right, lower area of the passanger side head when installed.
2001/2002 Ls1 heads were marked 241 in the same area. Pre-2001 heads were machined in this area, with no markings, just the milled out area.
The "D" shaped ports should also be a give away.
[Modified by CJS, 9:23 PM 10/3/2002]
Oct 3, 2002 | 10:03 PM
These are the only numbers I am aware of for the LS6 heads.
2001: 12560801
2002: 12564825
The ’02 valves weigh less and are longer than other LS1/LS6 valves. As far as the ports go, they don’t look like stock LS1 ports but they don’t look like stock LS6 ports either :confused:
Oct 3, 2002 | 11:25 PM
Re: Are these Really 02 LS6 Heads? (SFVetteman)
Oct 3, 2002 | 11:28 PM
i didn't look at your link the first time around... i was just answering the question about the color of the springs...
with the round ports, it doesnt look like an LS6 head.
look at the pics of these 2001 LS6 heads
source:
http://www.metricchemical.com/engine2.htm
[Modified by don527, 10:29 PM 10/3/2002]
Oct 4, 2002 | 12:14 AM
Re: Are these Really 02 LS6 Heads? (don527)
They are being advertised on Ebay. I call BS on the ports too. Pretty creative to try the yellow spring trick.
I asked for the casting number to see if it was the angle of the photo.
Thanks all!!
Oct 4, 2002 | 12:37 AM
thats not verygood as i am the lonely bidder on ebay.. :smash: :smash:
Oct 4, 2002 | 02:11 PM
If the number 243 is on the top corner they are LS6.
If the number is 241 they are LS1.
