Part II, Code P1415 H C
Old Aug 6, 2017 | 07:30 PM
57gman's Avatar
57gman
Default Part II, Code P1415 H C
Okay if you want to follow, see first thread earlier today.
What does the code above mean, it translates into Air System Bank 1, I'm not sure what that means.
Any suggestions? Because it occurred before (H) and now (C)
And the check engine light is still on. Help. What can I check my self?
Old Aug 6, 2017 | 07:56 PM
twokbolt's Avatar
twokbolt
That's for the exhaust check valve on the driver's side. Thank your stars it's not 1416. That one is a bit of a pain. The one you have is much easier to access.
Old Aug 6, 2017 | 09:12 PM
57gman's Avatar
57gman
Just a thought, since it had the H behind it and the C behind it, could the C eventually go back to H and the check engine light go off?
What's the probability of that happening?
Old Aug 6, 2017 | 09:24 PM
StingrayRebel's Avatar
StingrayRebel
just clear the code and see if it comes back
Old Aug 6, 2017 | 09:59 PM
twokbolt's Avatar
twokbolt
You can clear the code and it may stay gone a while. It likely will not stay gone for good though.
To Part II, Code P1415 H C
