Unlocking Cable not working
Old Aug 12, 2017 | 11:09 AM
Niklas Ekbladh's Avatar
Niklas Ekbladh
8th Gear
Default Unlocking Cable not working
So I had the classic "Pull key, wait 10 seconds" and "Service Column Lock" so I went ahead and purchased the Column Lock simulator and installed it, that got rid of the messages. I then tried the unlock cable but it does not unlock the column lock. I checked the cable for voltage and the cable seems OK. Kind of lost what to do next since removing the steering column trim involves removing the steering wheel.
Am I right to think that when I plug the unlock cable in to the column lock contact and power it using the cigarette plug I add power directly to the column lock motor?
If so, is the column lock motor broken or can there be an other component involved?
...and yes, I have read the Sticky.
Old Aug 12, 2017 | 11:36 AM
Niklas Ekbladh
8th Gear
Column lock simulator installed.
Unlock cable plugged in.
Unlock cable.
Column lock motor contact.
Old Aug 12, 2017 | 12:17 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
I just went through the wait,count 10 sec..... I was sent to these folks....Not only did it work but the support (Richard) was over the top.
Check with them here,,
http://www.complianceparts.com/index.html
mike v
Old Aug 12, 2017 | 02:51 PM
mike venth's Avatar
mike venth
mike v
Originally Posted by 8VETTE7
Thread starter doesn't have an LMC5 installed but rather chose to go with the older CLB solution so his problem likely is NOT the same as yours and unlikely Richard can help with the CLB and NOT the LMC5.......
Learning something new every day-Thanks 8vette7 for the heads up
Old Aug 12, 2017 | 02:59 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
when you apply power to the column lock you should hear it unlock if it is locked....
you can always pull the fuses, disconnect the battery for a few minutes, reconnect and try again although I installed a few of these and never had the issue where the column wouldn't unlock when power was applied.
I would find it odd that you would have enough power to lock the column and do other things yet not enough to unlock the column
Old Aug 12, 2017 | 03:14 PM
Niklas Ekbladh
8th Gear
mike v
Like 8Vette7 said, it's not the LMC5, got that one first but it didn't come with an unlock cable so I went for the CLB instead. I can add that this is an EU model and that I live in Sweden. Parts are not as easy to come by as in the US.
Old Aug 18, 2017 | 03:53 AM
Niklas Ekbladh
8th Gear
managed to get the trim panels around the steering wheel off yesterday and used a rubber mallet to tap on the column lock motor, after alot of tapping and som force the wonderful "dzzzt" sound came and the steering wheel unlocked. Disconnected the negative battery node and installed the CLB. Re-attached all the panels and switches, finally back on the road!!
To Unlocking Cable not working
