Skip shift eliminate interchangeability
Old Aug 12, 2017 | 05:39 PM
camaro430sut's Avatar
camaro430sut
Default Skip shift eliminate interchangeability
Any one know if the skip shift is the same between 05 GTO and C5 Vette. I kept the skip shift from my GTO but it throws a code in my 02 Vette. Any ideas?
Old Aug 12, 2017 | 06:17 PM
camaro430sut
Damn Austrailian car, one of the reasons I sold it
Old Aug 12, 2017 | 08:44 PM
feeder82's Avatar
feeder82
Solder in a new resistor, the c5 resistor is 2.2k -ohm, 1/2 watt
Old Aug 12, 2017 | 09:54 PM
camaro430sut
So I did some research on the GTO forum. They're the same resistance and wattage as a C5. So what gives? It should work
Old Aug 12, 2017 | 10:40 PM
camaro430sut
Most that I see cover both cars under the same number
Old Aug 13, 2017 | 01:56 AM
Bill Dearborn's Avatar
Bill Dearborn
Forget about it. Skip Shift is a non problem. Just drive around it. When taking off slow from a stop shift to 2nd gear before 14 mph or after 19 mph. Easy to remember except when you are in heavy traffic following somebody closely. That is when you will tend to delay the shift into the skip shift area and the shifter will move to 4th gear. When you feel that happening quickly move the shifter forward into the beginning of the 3rd gear gate and pull back into 2nd gear. Can be done in one fluid motion once you get used to catching it. No sense spending the time figuring out what is going on with your module.
It isn't worth spending 5 minutes on it.
Bill
Old Aug 13, 2017 | 09:09 AM
camaro430sut
I'd rather spend the 5 minutes, but thanks for your insight
Old Aug 13, 2017 | 10:08 AM
LoneStarFRC's Avatar
LoneStarFRC
Default Another Option
Skip shift can also be turned off completely by most any tuner using HP Tuners or EFI Live.
HTH
To Skip shift eliminate interchangeability
