any help with P0443 H
Old Aug 16, 2017 | 06:00 PM
Jason Faywood's Avatar
Jason Faywood
4th Gear
Default any help with P0443 H
I'm out of time in need of help, My smog is due in a couple of weeks and my 2001 c5 automatic convertible keeps throwing P0443 H I have so far replaced...
Fuel Pipe Assm to Engine Purge Valve-
12573363 - TUBE - (the other side of purge valve connection)
And the actual OEM Canister Purge Solenoid Valve For Buick Chevrolet GM 214-641 1997278.
So to recap the code calls for the purge solenoid valve to be replaced I did that first, cleared the code with my scanner tool and the code came back so I replaced both hoses, tubes, pipes what ever they are called that goes to it and from it and still the code continues as an intermittent problem. it happens often enough that I can't pass my smog cert.
Any other suggestions are a good place in southern California to take it?
