C5 T56 in a C6
Old Aug 19, 2017 | 03:44 PM
ogulcanio's Avatar
ogulcanio
Default C5 T56 in a C6
Hello everyone,
My friend messed up his trans in his 05 c6
Can a T56 from a 04' C5 used as a direct replacement for the one in 05'?
Old Aug 20, 2017 | 03:26 PM
dmaleck's Avatar
dmaleck
Yes, it can be installed from an 04 to an 05 BUT you will need to swap the rear housing from the c6 trans to the c5 trans. This will also require you to reshim the extension shaft.
Old Aug 23, 2017 | 03:59 PM
ogulcanio's Avatar
ogulcanio
Thank you very much!
But they are both using the same output shaft right?
Old Oct 8, 2017 | 11:18 AM
dmaleck's Avatar
dmaleck
Just seen this now. Yes, they both use a 27 spline main shaft.
To C5 T56 in a C6
