04 C5 z06 overheating 57k miles
Last night driving around 80 degree temps outside car ran hot to about 260 bubbling coolant my fans won't come on can't figure out which relay I need to swap out if so which one cause I doubt it's my thermostat cause they don't control the fans
Here is the wiring diagram. There are 3 fuses and 3 relays:
Might not be either fuses or relays. Could be you sucked in a plastic bag or other debris from along the road and its wrapped around the fans. C5 being a bottom feeder for cooling air they suck up what ever is on the road..............
If the temp got to 260 and the fans did not come on it is either electrical or mechanical.
I would definitely check the actual fan motors for debris blocking them from turning. And while you are under the car for that check the wiring and connectors for the fans to see that it is not damaged.....
There is no SINGLE relay or fuse failure that can prevent BOTH fans from running. Would have to be a multiple electrical failure for NO FANS to run.
