LS1 piston/rod replacement
Old Oct 4, 2002 | 04:04 PM
jpas's Avatar
jpas
Default LS1 piston/rod replacement
Is it possible to replace the pistons & rods in a C5 without removing the block?
Thx
Old Oct 4, 2002 | 04:17 PM
QwikSilvr's Avatar
QwikSilvr
Default Re: LS1 piston/rod replacement (jpas)
I don't believe so.
Old Oct 4, 2002 | 04:43 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
No.. The pan has to come off, which is really only possible with the motor pretty much right out of the car... Honestly, it isnt that much bigger of a deal to pull out the whole engine if you already have the car all tore apart... You would need a cherrypicker though..
Old Oct 4, 2002 | 04:56 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Thx
While you are at it, throw in a 4.00" stroker crank and you'll have one monster.:D :cheers:
Old Oct 4, 2002 | 06:50 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Sure can :yesnod: Just remove the craddle to remove the oil pan,pull the heads and you are there...I replace the rings with the motor in the car and it is less time consuming compared to removing and reinstalling the motor...
Old Oct 5, 2002 | 01:20 AM
lost's Avatar
lost
Default Re: LS1 piston/rod replacement (C-5 TECH)
You are joking, aren't you. Our shop has a lift and we only use it on vans etc, when the engine has to come out the bottom. twenty years and 10,000 motors and have been doing it wrong all this time...I know it can be done, but it sounded like the person who asked the question was probably going to attempt this job in his garage on jack stands.
Old Oct 5, 2002 | 01:58 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: LS1 piston/rod replacement (lost)
Maybe if your superman i.e. C5 TECH, but if you don't have super powers like most of us, you should just yank the dang thing!
BTW: pulling the body work is totally optional.
[Modified by Gary2KC5, 11:59 PM 10/4/2002]
Old Oct 6, 2002 | 01:54 AM
redbob's Avatar
redbob
YES you can it is not a big deal and it is a lot quicker than dropping the motor and you can do it in your garage on ramps.
[Modified by redbob, 9:59 PM 10/5/2002]
Old Oct 6, 2002 | 09:58 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: LS1 piston/rod replacement (redbob)
[QUOTE]YES you can it is not a big deal and it is a lot quicker than dropping the motor and you can do it in your garage on ramps.
I guess that answers that...
:cheers:
Old Oct 6, 2002 | 06:00 PM
jpas's Avatar
jpas
Thanks for the responses!!! I'll give it a try, and if I end up needing to pull the block, no big deal.
Old Oct 6, 2002 | 06:06 PM
C5Noir's Avatar
C5Noir
redbob, could you post some install tips for this? Thanks.
Old Oct 6, 2002 | 06:24 PM
chuckster's Avatar
chuckster
Well I can tell you first hand it can be done.. I was my dealer a few months ago. They had a guy in there that hydolocked his motor (Witha STOCK INTAKE) but I digress....
Anyway, the motor was completely open. I was was looking right though the cylinder walls to the floor... It was like looking at open heart surgery
And yes the block was still attached to the motor mounts..
To LS1 piston/rod replacement
