AC stopped working
Old Aug 24, 2017 | 01:38 AM
Corvette#2's Avatar
Corvette#2
Default AC stopped working
I had a new compressor installed 4 months ago. Everything was fine until a few weeks ago. They AC started cycling. Worked ok for 10 seconds, shut itself off for 10 seconds etc.. Now it goes off almost the instant I turn it on. I'm going to bring it back to the shop that put in the compressor. Any idea what's wrong with it ? I'm thinking one of the temp sensors ? The external temp sensor has been flaky for a while. Often times it will show 75 degrees when I know the real outside temp is ~100. But from what I've read, the AC only shuts itself off if it detects the outside air is below freezing.
Old Aug 24, 2017 | 11:34 AM
DVUSz06's Avatar
DVUSz06
It sounds like you may have a small leak in the system. Have you checked the charge in the system? Just a thought.
Old Aug 25, 2017 | 09:30 AM
huesmann's Avatar
huesmann
Compressor won't run if refrigerant pressure is low/zero.
To AC stopped working
