Speed Bleeder install question
Old Aug 24, 2017 | 06:33 PM
JESSTERLSX's Avatar
JESSTERLSX
Default Speed Bleeder install question
Hey gang Just had my Clutch Master Cylinder go out. Planning on buying a Tick Performance CMC and a Speed bleeder along with it. Will it be possible to install the speed bleeder on the slave without removing the Torque Tube? I've done the install on Fbodies when replacing the whole clutch so the transmission was already off when I installed the bleeder. So I have never dealt with the Torque tube on our cars nor tried with the slave installed. Thanks for any input.
Old Aug 25, 2017 | 02:10 PM
Scotty_Z06's Avatar
Scotty_Z06
Lol, as far as I know the only way to change it without removing the torque tube would be to go at it from the other side and pull the motor.
Old Aug 25, 2017 | 03:09 PM
JESSTERLSX's Avatar
JESSTERLSX
Well im not looking to change the slave. Just put the speed bleeder on it which goes in place of the factory bleeder next to the clutch line. But I'm working O/T all weekend and next week so I haven't had a chance to get under it and look at it.
Old Aug 26, 2017 | 11:44 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Pretty much impossible.
I've heard of it being done once, but have no idea where to find the reference. Heck, even just trying to bleed/crack the line with the stock setup is tough, much less installing a whole new bleeder assembly.
Old Aug 27, 2017 | 01:30 AM
JESSTERLSX's Avatar
JESSTERLSX
Gotcha. I'll have to look at it and see what I can do once I get it jacked up. I know I can probably remove the factory bleeder but getting the speed bleeder in there and tightened down is another story. If I can, I'll make a how to video for you guys haha!
Old Oct 20, 2018 | 09:47 AM
helga203's Avatar
helga203
You ever changed your bleeder???
Old Oct 20, 2018 | 10:29 AM
f6john's Avatar
f6john
Subscribed just in case you’re succeeding!
Old Oct 20, 2018 | 10:44 AM
Moved to the Tech side.
Old Oct 20, 2018 | 10:53 AM
Gordy M's Avatar
Gordy M
There were several articles years ago on how it can be done by removing the intake manifold and going underneath (required small hands as I recall). Try a google search!
Old Oct 20, 2018 | 01:00 PM
Spaggs's Avatar
Spaggs
Small hands, like baby size. My hands are small compared to most guys and I tried every which way I could. No luck. I'm taking this opportunity to inspect the bearings and replace couplers with polyurethane and put in a sturdy twin clutch.
If you can do it without pulling the TT, you are a better man than I am.
Spaggs
Old Nov 6, 2018 | 12:37 AM
JESSTERLSX's Avatar
JESSTERLSX
Geez guys I haven't logged on in a while please forgive me. And no unfortunately I was not able to. I have big hands and even if they were smaller the area that you have to reach to tighten down the bleeder is further into the bell housing. So you would have to blindly shove the hose in there and the nut spins on the hose so you can't spin the hose to tighten it. You would have to also somehow fit another hand in there with a wrench and blindly tighten it, if you even got it started. I ended up having a friend help me bleed it the old fashioned way. I'll eventually need a new clutch and when that time comes I'm going to pull the whole drive line and go through it. New Torque Tube bearings, slave and etc. And that's when I'll install the bleeder.
To Speed Bleeder install question
