T 1 sway bars
Old Oct 4, 2002 | 07:20 PM
c5 shawn's Avatar
c5 shawn
Default T 1 sway bars
Does anyone have T 1s on there car that are quiet. If so how did you
get them to be quiet.Had them on my car for about a month and the clunking over bumps drives me nuts.I loved the way the car handled but the clunking is so annoying.I have the Zo6 bars on my ride for now,
until i figure something out.I know this is a racing part but there has to
be a way to silence them.
Old Oct 4, 2002 | 08:21 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: T 1 sway bars (c5 shawn)
I have them for 35,000 miles and never heard a thing. Don't know why maybe end link adjustment o car height???????
Old Oct 4, 2002 | 10:58 PM
JLinCA's Avatar
JLinCA
I would get down under there and make sure everything is tight. I recently solved a problem with clunking in my front end, the driver side front endlink on my Hotchkis bar was very loose.
I tightened that thing as much as possible and it's been fine ever since.
Old Oct 4, 2002 | 11:01 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Default Re: T 1 sway bars (John Shiels)
John,
Please enlighten me also as I just installed T1's on my vert and with the heim links it rattled at slow speeds only and especially on slow bumps-made me not want to drive it. Recently I re-installed the factory end links on the rear and Hotchkis end links on the front. So far I only have a little rattle on the front left and none in the rear but deep slow dips and some slow speed bumps do make a sound from the bushings which I pre-greased.
Any help would be greatly appreciated. :D
Definitely no clunking though.
[Modified by xtream1, 7:03 PM 10/4/2002]
Old Oct 4, 2002 | 11:04 PM
Stingray1967's Avatar
Stingray1967
Default Re: T 1 sway bars (xtream1)
Hey, I've got a slightly off topic question. How bad of an install was the sway bars? Can I do it with ramps and a wrench?
Old Oct 5, 2002 | 04:44 PM
c5 shawn's Avatar
c5 shawn
Default Re: T 1 sway bars (Stingray1967)
Thanks guys,i know everything is tight but i may have over torqed the
bushings.
Stingray 1967 swaybars are very easy to install if you have a way
to lift the car.
Old Oct 5, 2002 | 07:11 PM
Stingray1967
bushings.
to lift the car.
By lifting the car, do you mean a 4-post lift or a jack?
Old Oct 5, 2002 | 09:16 PM
c5 shawn's Avatar
c5 shawn
A 4 post lift would make it alot easier but jack stand will work.
To T 1 sway bars
