Best performance mods for the C5???
Old Oct 5, 2002 | 01:39 AM
PeeWeeC5's Avatar
PeeWeeC5
Default Best performance mods for the C5???
What are the best performance mods for the c5's in yall opinion? What would be th cheapest, quickest, and easiest way to get a 01' A4 w/2.73's into the mid-high 11's..?Feedback is greatly appreciated.. By the way the car already has the SLP loudmouth on it...Thanks..... :D
Old Oct 5, 2002 | 01:46 AM
chuckster's Avatar
chuckster
Default Re: Best performance mods for the C5??? (PeeWeeC5)
Gears...nuf said... :smash:
Old Oct 5, 2002 | 07:24 AM
Mitch C's Avatar
Mitch C
If you want to run mid to high 11s you need to do heads and cam, at least a 3000 or more stall converter, 3.42 or better yet 3.73 gears, headers, underdrive pulley, proper programing, LS6 intake if your car is older than a 2001 and you will need a good set of tires(DRs or ET streets) to give you traction. I am not a fan of nitrous but that would be the cheapest way to run fast if you don't want to spend a lot of money on the other mods I mentioned.
98 A4
Powerloaded
Donaldson Blackwing
PT2400
3.42 Gears
:yesnod: :yesnod: :yesnod:
[Modified by Mitch C, 5:32 AM 10/5/2002]
Old Oct 5, 2002 | 08:48 AM
Crushinator's Avatar
Crushinator
Default Re: Best performance mods for the C5??? (Mitch C)
Gears, tires and a power adder. (either Nitrous or a supercharger) There's your ticket to the 11's.
Old Oct 5, 2002 | 08:53 AM
batsallover's Avatar
batsallover
Default Re: Best performance mods for the C5??? (chuckster)
Gears....shift kit, torque converter.
For A4's, a low mileage 3.42, transgo, and Yank converter (2800 or higher)
:yesnod:
Under 1300 for the parts and 500 for the labor unless you DIY.
Old Oct 5, 2002 | 09:02 AM
Crushinator
Default Re: Best performance mods for the C5??? (batsallover)
:yesnod:
Yeah, but gears alone aren't gonna get a stock automatic Vette into the 11's. You'll need more power too.
Old Oct 5, 2002 | 10:03 AM
vstella's Avatar
vstella
Default Re: Best performance mods for the C5??? (QuickSilver97)
It's NOT esy and you will surely need to lose the stock T/C and those 2.73's ..I've got the mods to go 11's and I'm sooo close but still not there..:yesnod: I'm just waiting for the cooler fall weather to get to South Florida..That should do it for me!!:D Check out my homepage for videos of all my 12.00 -12.10 passes at the track.
So much depends on the weather,track conditions , traction ,skill of the driver. Mods alone are only the beginning. You've got some work to do! :yesnod:
Old Oct 5, 2002 | 04:26 PM
6500RPM's Avatar
6500RPM
Gears, Torque converter, Nitrous, and Tires
:yesnod:
To Best performance mods for the C5???
