P0418 code
Old Sep 3, 2017 | 10:01 AM
bturges's Avatar
bturges
1st Gear
Default P0418 code
I have a c-5, 2000 corvette, been getting this P0418 code which is described as secondary air pump circuit a relay, I changed the pump itself and it was good for 30 miles, came back on, my question, where is this relay??? any help???
Old Sep 4, 2017 | 09:28 PM
royal flush's Avatar
royal flush
Likely a relay in fuse box in engine comp. by battery--lift of lid and will show which relay--replace--hopefully good to go-
Old Sep 5, 2017 | 03:31 PM
runner140*'s Avatar
runner140*
Originally Posted by 8VETTE7
If you have an owners manual there are layouts of both fuse boces in the back of the manual that identify the use of each fuse, relay, ckt breaker. If you don't have an owners manual then here is a PDF for your year:
http://www.corvetteactioncenter.com/...00corvette.pdf
Guys that don't have a copy, best mark the above on your favorites.
I have both, the manual and the PDF and still use them.
To P0418 code
