Problem with Gas Door Switch
Old Oct 5, 2002 | 12:11 PM
Monkeyboy's Avatar
Monkeyboy
Default Problem with Gas Door Switch
As I've posted elsewhere (http://forums.corvetteforum.com/zerothread?id=403481), I've been doing some things in the interior of my 01 coupe that have required repeated removal and reinstallation of the armrest and console assemblies. Yesterday, I was unhappy to find that the gas door switch didn't work. I was in a hurry (at the gas station, naturally), and didn't have time to inspect the switch assembly, but from memory, there is some kind of small circuit board beneath the switch, and what must be a simple contact connection (I don't recall any kind of plug) that must engage when the armrest assembly is mated to the "tunnel". Is this right? What kind of failure could be causing this? Any known glitches for me to look for?
Greg Burch -- -- 01 Torch Red Coupe: http://gregburch.net/cars/vette20020907.html
Performance Mods: Blackwing filter/intake, drilled "foglight ducts", Granitelli MAF, Vortex airbridge, smooth coupler; Z06 wheels & tires, Borla Stingers, X-pipe, Hurst shifter
Information Mods: Pentium 4, 10" VGA touch screen; GPS nav; Autotap
Appearance Mods: BPE fixed headlights, blacked-out lower rear fascia; TR exhaust plate
Upcoming Mods: ?
Old Oct 5, 2002 | 01:12 PM
MelloYellow's Avatar
MelloYellow
Default Re: Problem with Gas Door Switch (Monkeyboy)
Ya, underneath the switch it probably came disconnected. Mine did this once too while working on the center console.
There is an emergency release wire over top of the driver rear wheel well, under the carpet. Long wire. Give it a hard tug.
