Different tire brands
Old Oct 5, 2002 | 05:26 PM
GrandMasterFlash's Avatar
GrandMasterFlash
Default Different tire brands
Is it ok if you have the runcraps in front and another brand in rear, could this combination cause some bad stability when driving hard :confused:
Old Oct 5, 2002 | 06:37 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Re: Different tire brands (GrandMasterFlash)
I'd be real concerned about the side walls not having the same strength. :eek:
Old Oct 5, 2002 | 07:40 PM
mozin's Avatar
mozin
There is no way I would mix tire brands.
Old Oct 5, 2002 | 08:52 PM
G 99's Avatar
G 99
Default Re: Different tire brands (mozin)
:nono: :nonod: Just like drinking....don't mix.
Old Oct 6, 2002 | 01:31 AM
Richin Chicago's Avatar
Richin Chicago
Not a good deal and also not real predictable.
Old Oct 6, 2002 | 02:13 AM
magnetic1's Avatar
magnetic1
Default Re: Different tire brands (Richin Chicago)
I woudlnt do it if it were me.
Different grip, as well as different handling between f/r.
Old Oct 7, 2002 | 12:55 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Different tire brands (magnetic1)
I put new Firestones runflats on the back and kept the Goodyear runflats on the front because they still had a lot of tread left---and I haven't had any problems whatsoever. On the other hand, I don't do a lot of aggressive driving so it probably isn't as noticeable. I will, however, be putting new FS on the front in about a month. Given the choice, I would run the same tires on all four corners.
Old Oct 7, 2002 | 10:13 AM
vetdude's Avatar
vetdude
:nono: :nono: :nono: Just remember the two most important factors regarding your well-being (staying alive) as a vehicle operator - good tires and brakes. These are two areas where you never want to be frugal. I wouldn't mix tire brands on my Jeep let alone the Vette. If you need more convincing, just go the http://www.tirerack.com website and see for yourself. :smash:
Old Oct 7, 2002 | 10:18 AM
dangrass's Avatar
dangrass
I wouldn't foresee a stability issue, but the overall effect would depend on what tires were on the rear. The Goodyear runflats have very still sidewalls and as a result are not very compliant, which seems to be a bigger problem on the rear than the front of a C5. If I were to assume that you would be running a non-runflat on the rear, chances are they would be more compliant and likely stick a little better than the fronts. The result of this would be that the car would tend to understeer a little more than before (more traction in back relative to the front). This is a very safe condition.
Dan
To Different tire brands
