Eng temperature
Old Sep 8, 2017 | 06:42 PM
LPZ's Avatar
LPZ
8th Gear
Default Eng temperature
LS1 ran at about 190 degrees F, on the dash temp gauge. put a different rad now is runs at 210 degrees F. what is the normal operating temperature? thanks LPZ
Old Sep 9, 2017 | 04:09 AM
strand rider's Avatar
strand rider
I on the other hand, agree with the professional engineers who designed the thing, that the engine has a carefully considered operating temperature., as a part of a sophisticated engine design program. The cars don't come off the line with just any old operating temperature, they were state of the art machines at the time, with a lot of money invested in the success of the product.
Regretfully, I don't have the answer off the top of my head, but your temps sound ok.
The rest is just a collection of stuff I have learned here, you probably know the stuff, but I need spelling practice
I read these post to improve my understandings, not to memorize stuff I can look up., but If I am correct , your new radiator is running ok. Some people don't understand newer engines are designed differently, and want the new car gauges to look like the old days . So they change the easy stuff , a thermostat mostly , or if they need one, a radiator. And are not bashful to post how they really improved the design, but never offer a reason beyond observed temperatures in normal operation.
I recently read a very knowledgeable post here about thermal expansion considerations, the fuel curves and timing changes needed when changing engine temperatures away from the stock design, even going into Rpm effects. I got the impression the guy was a racer, as he made his points with ease and presented the reasons for his statements, getting his point across better than most engineers, with the same understandings.
Of course, if you don't have a stock engine, other systems have to follow. IF , like me, the car is stock enough to not need to re-engineer a major system you are ok, my new radiator runs well over 200 normally and triggers the fans correctly.
The lower temp when you got the car might just be some guy screwing around because they can. But sometimes supercharged cars require lowering the operating temps. It is not unusual to take off the bolt ons power adders before selling the car. A car like that might also have its smog system removed, and those parts are too expensive to replace for sale in a normal market. The fact that the old radiator ran cold might indicate missing power adders, but not always.
AS I said at the beginning, I am just repeating stuff, and never mean to mislead, but it should be checked.
Old Sep 9, 2017 | 07:36 AM
runner140*'s Avatar
runner140*
Suggest you re-read post #2 (8vette7). Sounds like a burp problem.
Easy way....from a cold start, remove pressure cap, bring up to temp while adding coolant...to the top. Replace the cap. Repeat the above several times. Do not over fill the overflow tank.
There are several ways to burp the system. The above works for me.
There is no normal...mine runs at 170+ on the highway and up to 200 in traffic.
Old Sep 9, 2017 | 11:35 AM
LPZ's Avatar
LPZ
8th Gear
Default eng Temp
Originally Posted by 8VETTE7
No such thing as a normal temp for a C5 to run/operate at. Varies all over the lot depending on many, many variables. There are many dozens of threads about what is hot and what is not for the C5. NO AGREEMENT.
If yours ran at 190 BEFORE the rad swap then I would make certain that the air is completely burped out of the system and that the coolant is at the proper level.
Thanks for your reply LPZ
Old Sep 9, 2017 | 11:37 AM
LPZ's Avatar
LPZ
8th Gear
Thanks for responces to Eng Temp LPZ
Old Sep 9, 2017 | 05:47 PM
lionelhutz's Avatar
lionelhutz
190* is not running cold. It is the low end of the normal possible operating range. 236* is the point where the fans kick on to high speed so that should be the highest temperature.
If you put in a better quality rad then it should not run hotter.
To Eng temperature
