B&B PRT Install Problem.....
Old Oct 5, 2002 | 11:05 PM
Dicecal's Avatar
Dicecal
Default B&B PRT Install Problem.....
I am in the process of installing PRTs with the elliptical tips on my 2001 Coupe. Everything was going great until the passenger side over the axel pipe. It is bent too far towards the center of the car, and the end of the pipe is almost against the storage compartment that dips down in the middle. I cannot get the muffler on properly, even if I could, the pipe would be vibrating against the storage compartment and the muffler would be at an angle. Anyone ever have this problem? I guess I'll call B&B and try another over the axel pipe. Any other ideas? Thanks!
Old Oct 6, 2002 | 08:48 AM
jschindler's Avatar
jschindler
Default Re: B&B PRT Install Problem..... (Dicecal)
It sounds like you may have two pipes made for the same side. Look at the flange. There should be a "D" embossed on one (for Drivers Side) and a "P" on the other (yep, passenger side). That's the only thought I have.
Good luck.
Old Oct 6, 2002 | 12:30 PM
Dicecal's Avatar
Dicecal
Default Re: B&B PRT Install Problem..... (jschindler)
I looked at both pipes...many times. The D pipe fit great on the drivers side. The Pipe stamped with a P seems to be bent too much towards the center. I even tried switching the pipes incase they were improperly stamped. There is no way the P pipe is going to work, maybe I just got a bad pipe. At least I hope thats all it is.
Old Oct 6, 2002 | 05:20 PM
jschindler's Avatar
jschindler
I just noticed where you live. Looks like you can have this resolved tomorrow. Good luck.
To B&B PRT Install Problem.....
