Coolant change questions
Old Sep 18, 2017 | 05:37 PM
OUTAKTRL's Avatar
OUTAKTRL
Default Coolant change questions
What's up guys. Wanna do a coolant change of dexcool should I replace it with full strength Dexcool ? Or the 50/50 pre-mixed Dexcool that says not to add water on the gallon jug ? How many gallons will I need to refill. Any other help or info will be appreciated
Old Sep 18, 2017 | 05:58 PM
JBB's Avatar
JBB
Not sure what you have but my 02 base model holds 12.6qts. I'd get the full strength & mix with distilled (store bought) water. The premix is easier if you like.
Old Sep 18, 2017 | 06:08 PM
Grandpa1's Avatar
Grandpa1
I just did my 03 Vert. It says 3 gallons total. I bought 2 gallons full strength dex and 2 gallons distilled water.
I used the drain plug (which I promptly broke. Advance Auto had one thank God!) and pulled the bottom hose. I actually replaced top and bottom hoses.
I never got 3 gallons out of the car but the stuff was like new so I was content to replace the 2 or so gallons I did get out.
Easy job.
Be careful with that poorly designed drain plug!!!
Turn it about a quarter turn and pull out.
I would fire the genius that designed it. Very stupid. If you are reading this, you idiot, you owe me 5 bucks!
Old Sep 19, 2017 | 01:29 AM
foggy's Avatar
foggy
Never put "full strength" coolant in straight.. It's meant to be diluted with water/
if you don't want to mess with mixing it, buy the prediluted Dexcool..
IF you don't mind mixing, it's cheaper to get the full strength and mix it yourself
Old Sep 19, 2017 | 07:02 AM
runner140*'s Avatar
runner140*
Why pay those prices for DexCool - 50/50% mix when distilled is only .88 a gallon.
Old Sep 19, 2017 | 07:52 AM
MatsA's Avatar
MatsA
2024 C6 of the Year Finalist - Modified
is it as simple as it sounds to do or is there any bleeding of air process involved ?
To Coolant change questions
