This happened when I instlled a new PS pump...
I have four bolts and one is shorter than all the rest and the forum guy said to mark it with tape and I did not as I was already past that step...Please help does anyone know which hole gets the smaller bolt?
these are not the bolts that hold alternator on...
they re the bolts that hold the bracket into the engine wall.
It cause an inexcusable chirp...
You guys have never failed me so im hoping someone readily has an answer.
if you have a laser alignment tool check the pulley alignment... if the belt is good and it still makes noise pulley misalignment is a big cause of that
