Why is Throttle Not Linear?
Old Sep 23, 2017 | 11:55 AM
ChrisLSx's Avatar
ChrisLSx
Default Why is Throttle Not Linear?
Specifically why is the Accelerator Pedal Position % vs Throttle Position % not 1:1?
Looking at the stock C5 table for APP vs TP, even at 75% pedal the throttle is only commanded 46% open. It's only the last 25% of pedal travel that the throttle goes wide open (and then it's pretty much all at once). Can someone enlighten me on the reasoning behind this?
It would seem to me that the throttle should follow the pedal near 1:1.
Specifically, I'm looking at the table on a 2004 manual C5 coupe using HPTuners (though files from other year C5s seem to be near identical).
Old Sep 23, 2017 | 05:25 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Because drivability would suck.
That's really the nuts and bolts of it.
Old Sep 23, 2017 | 07:01 PM
ChrisLSx's Avatar
ChrisLSx
Suck how? Too touchy/not enough resolution at low throttle (throttle becomes an on/off switch)?
Old Sep 23, 2017 | 07:32 PM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
It would be very twitchy
Old Sep 23, 2017 | 08:17 PM
ChrisLSx's Avatar
ChrisLSx
Yes... yes it is (on a whim I decided to try true 1:1 and yeah, it's not drivable like that).
However, I did set the 50%+ APP = 50%+ TPS and then scale the lower half to transition smoothly. By keeping the lower range (<25% APP) near stock, it's very drivable (to me) and yet much more responsive.
Old Sep 23, 2017 | 10:08 PM
StingrayRebel's Avatar
StingrayRebel
so you're telling me that we don't need a cow booster??
Old Sep 23, 2017 | 10:20 PM
ChrisLSx's Avatar
ChrisLSx
moo
Old Sep 24, 2017 | 06:15 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Old Sep 24, 2017 | 09:09 PM
sirdano's Avatar
sirdano
And that is the secret some tuners don't want you to know.
You might get silenced for this secret telling
Old Sep 24, 2017 | 10:23 PM
lionelhutz's Avatar
lionelhutz
It's not been mentioned, but moving the angle of the throttle shaft linearly does not cause a linear increase in the throttle body cross sectional area. Even the older TBI, LT1 and cable LS1's had a cam that caused the throttle shaft to move slower at first and then faster as the cable pulled more. Still, you'd be right that the curve doesn't make the area open linearly.
Old Sep 25, 2017 | 04:05 AM
romandian's Avatar
romandian
are you talking about "max. rotation versus pedal" in hp tuners? (i only have the demo version.)
what difference does it make if you depress your pedal slower or faster? i found a tune where you get 100% throttle from 60% pedal up. no idea how that makes sence.
Old Sep 25, 2017 | 10:24 AM
Gordy M's Avatar
Gordy M
In the drive by wire TB, you have a built in delay, if your tune gives you wide open throttle at 60% pedal, it will still scale the the acceleration rate back to the standard set in the nonn programmable portion in the PCM. There are ways around this system but changing the relationship of throttle to TB response is not an easy tuning solution. What works at one setting will cause twitching, bucking or undrivable conditions in another situation.
Old Sep 25, 2017 | 01:45 PM
ChrisLSx's Avatar
ChrisLSx
See attached screen shots. The first two are stock 2004 C5 throttle maps. The second two are what I have mine set at. Notice that from 0% to 9% they are very similar. This was necessary to have any low speed resolution. At 13% mine starts to start a gradual ramp up. This was needed to keep from having a very abrupt transition from "stock" to "modded" values.
Old Sep 25, 2017 | 07:37 PM
Rick Griggs's Avatar
Rick Griggs
Default Geometry
Look at the bore as a circle, the disk(throttle) closed , it is a circle with a large area. As the disk opens it becomes a elipse, with each degree open it becomes a smaller area. As it gets closer to wide open it has a very small control of the conductivity of the of the tube it is controlling. If I continue explaining, I will probably misspeak, hope this helps
Old Sep 25, 2017 | 07:57 PM
ChrisLSx's Avatar
ChrisLSx
... At 0% (fully close) the throttle plate is flat against incoming air and event a 1% change in throttle plate angle will yield significant change in air flow capacity. By contrast, at 99% angle, the throttle plate is almost insignificant so the difference between 99% and 100% is near zero change.
The result is that small changes at "low throttle" yield significant changes in air flow capacity, which in turn affect driveability.
Old Sep 26, 2017 | 01:03 PM
Gordy M's Avatar
Gordy M
The 97-03 PCM has 512kb of information of which 96kb can be change/altered. The remaining 416kb is part of the GM adaptive strategy for running the engine management system. (2004 has 1056kb but still only 96kb programmable). The throttle lag between the DBW and TB opening is more than the two dimensional relationship of APP and TB opening. The work around is more involved and, of the 3 or 4 different tuning systems on the market for the LS engine, each have different methods of making the change. Be carefull when making those changes on your system and always save and notate each step of the changes.
Old Sep 26, 2017 | 06:42 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
My understanding is that it has more to do with meeting EPA requirements, both mpg and emissions. It has the added benefit, at least from a mfg warranty POV, of reducing drivetrain shock loads.
When I had mine dyno tuned at Livernois Motorsports, I asked them to make it linear...they told me I didn't really want that, but they would remap it for better response...and they did. Much improved over stock.
To Why is Throttle Not Linear?
