Vibration
Old Sep 25, 2017 | 05:49 PM
Kingb's Avatar
Kingb
5th Gear
Default Vibration
i have a 2000 corvette and I recently have a vibration in the rear end. It is most noticed around 65mph but is there at all speeds. It vibrates at the rate of 3 seconds smooth and 1 second of vibration. It is mostly noticed in drivers seat but I can still feel it in passenger as well. Any info would be much appreciated. Thanks.
Old Sep 25, 2017 | 06:03 PM
Moving this to C5 Tech.
Old Sep 25, 2017 | 06:29 PM
Kingb's Avatar
Kingb
5th Gear
Default Vibration
Vetteman jack. I am new to this site as I am a new vette owner. Not sure I understand what do I need to do
Old Sep 25, 2017 | 09:20 PM
namvet6869's Avatar
namvet6869
I also have a 2000 with the same problem. Not much but just enough to feel it in the seat. Checked everything, tires, balance, etc. Thinking what could it be. Mine turned out to be AC compressor. I've read it could be a number of things. My balancer is starting to wobble but no vibration yet but changing balancer next week for preventive maintenance. Hope you find your problem.
Old Sep 25, 2017 | 10:35 PM
El original's Avatar
El original
Check all belt driven components eg alternator, water pump, idler pulley etc. Bet one of them is piling up. Good luck.
Old Sep 26, 2017 | 06:39 PM
Kingb's Avatar
Kingb
5th Gear
Old Sep 26, 2017 | 07:22 PM
feeder82's Avatar
feeder82
he moved your post to the Tech section, problems are more likely to be solved here
Old Sep 26, 2017 | 08:17 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
start with the basics and look at the wheels really carefully to make sure that a wheel weight hasn't come off. maybe a self adhesive one came loose. look for telltale signs of a missing weight and make sure all the wheel lug nuts are in place.
Old Sep 27, 2017 | 07:56 AM
Kingb's Avatar
Kingb
5th Gear
Default Vibration
Ok. Thanks
Old Sep 28, 2017 | 12:03 PM
SaberD's Avatar
SaberD
I had something similar happen when one of my wheels got a slight bend on the inner barrel.
Old Oct 1, 2017 | 07:21 AM
Kingb's Avatar
Kingb
5th Gear
Thanks.
To Vibration
