ATI Damper Question
Old Oct 7, 2002 | 04:53 AM
LIGHTNING's Avatar
LIGHTNING
Default ATI Damper Question
What is it??
Was reading an article about chevy racing engines, & it mentioned an "ATI Damper." Have no idea what it is. :hat
Old Oct 7, 2002 | 12:55 PM
thunderbolt47's Avatar
thunderbolt47
Default Re: ATI Damper Question (LIGHTNING)
The ATI damper is an aftermarket replacement for the harmonic damper on the front of the crankshaft. Generally, aftermarket dampers are used for high rpm applications where the stock rubber ring unit might come apart.
Old Oct 7, 2002 | 01:46 PM
cmeb4dk's Avatar
cmeb4dk
How much? and does anyone have a part #?
Old Oct 7, 2002 | 02:20 PM
Joe's Eray's Avatar
Joe's Eray
Default Re: ATI Damper Question (thunderbolt47)
Thats what happened to me. That little rubber piece gave out and I had to buy a new one. Dont know if its an aftermarket one or not. It cost me around 100 bucks for a new dampner and 325 in labor because the mechanic had to remove my steering rack. Just a question though, am I going to have to worry about this new one going out?
Old Oct 7, 2002 | 11:33 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: ATI Damper Question (BrightRed C5 SWFL)
A new ATI balancer is about $ 450-475.00. They are a zero balanced unit that is SFI approved and is mainly designed for high horspower and/or high rpm applications. They are also rebuildable.
Note that they are only 10 % underdriven vs. a ASP that is 15%.
If you order one make sure they give you the A/C pulley!
Old Oct 8, 2002 | 03:04 PM
cmeb4dk's Avatar
cmeb4dk
Default Re: ATI Damper Question (9D9LS1)
Will it fit properly with a double roller chain?
To ATI Damper Question
