Mixing Different Octanes...
Old Oct 10, 2002 | 11:21 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Mixing Different Octanes... (hot1corvette1)
click on this link to see info on the storage tank. http://www.northerntool.com/webapp/w...=533&langId=-1
vetterdstr :cheers:
Old Oct 11, 2002 | 09:58 AM
bierbelly's Avatar
bierbelly
Default Re: Mixing Different Octanes... (vetterdstr)
Another option is to add an octane enhancer, like toluene or xylenes. Usually sold by the gallon in paint stores. DON'T get it on your paint.
Old Oct 12, 2002 | 02:22 PM
TeamZ06's Avatar
TeamZ06
Default Re: Mixing Different Octanes... (bierbelly)
I use toluene on the paint quite often to remove cone marks; never been an issue for me. Maybe it's the 40 coats of Zaino? Then again, toluene is used as a thinner for oil-based paints and has a 45 deg F vapor flash point; incidental contact with todays automotive finishes should be insignificant. Commercial grade toluene like you buy at the paint store usually contains high amounts of benzene, which is easily absorbed through your skin or inhaled as a vapor, as is toluene, both of which are rather toxic chemicals if they get in your body.
I'd be more concerned about getting it on yourself rather than your Corvette. Same thing applies to high octane unleaded gasoline, which often has a high content of these hydrocarbon solvents. Always wear protective gloves at a minimum when handling this stuff, seriously consider a respirator fitted with the proper hydrocarbon scrubber filters if contact with vapors is unavoidable, otherwise consider yourself an honorary member of the Huffer's Society; i.e this is your brain, this is your brain on hydrocarbon solvents - sizzle, sizzle! :smash:
Mark
Old Oct 12, 2002 | 03:30 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Mixing Different Octanes... (TeamZ06)
Mark
40 coats of Zaino + Toluene = NO MORE ZAINO :eek:
Try WD-40 :)
Old Oct 12, 2002 | 04:32 PM
TeamZ06's Avatar
TeamZ06
Default Re: Mixing Different Octanes... (Flyin'Brian)
Try WD-40 :)
wow, it sure shines and cleans like Zaino
besides, if that's the case it was probably already removed by the MEK solvent that I used to use :eek:
Mark
Old Oct 12, 2002 | 07:11 PM
Tom Steele's Avatar
Tom Steele
Maybe Zaino is toluene... ;)
[Modified by Tom Steele, 5:12 PM 10/12/2002]
