Climate control Module Problem 2000 c5
Old Oct 18, 2017 | 07:00 PM
Marked77's Avatar
Marked77
1st Gear
Default Climate control Module Problem 2000 c5
I have a newer climate control. Drivers side works fine. Just noticed that when you adjust the passenger side the dial does nothing on screen as if it were not there.....then you try the driver's side and works fine. This about a 2 year old OEM part. The passenger side blows warm air only. I have tried all the reset options and I do get a code Also I did take battery out of car cleaning my ac drain. The code says out of range. I think the control unit is faulty as it does not register the passenger side . Also the drivers side control **** has little clicks during turning but the passenger side only has one click at about halfway between warm and cold.
Old Oct 18, 2017 | 09:14 PM
El original's Avatar
El original
Passenger **** is working perfectly, does not show anything on screen as designed with only center click correct. As for blowing only warm...will let other guys comment on this one.
Old Oct 19, 2017 | 10:12 AM
Moving to C5 Tech.
To Climate control Module Problem 2000 c5
