Anyone have Cajundude's Vararam instructions
I am planning on installing a Vararam intake this weekend and have heard the install horror stories. Many old posts rave about Cajundude's install instructions but the website they used to be on no longer works.
Does anyone have his instructions saved somewhere they could share? Or anything better than what Vararam gives you? Thanks!
It's actually pretty easy. There is a YouTube video here
Also attaching the instructions I used (pdf).
Make sure while you're in there to blow out debris from the back of the radiator.
DrRaySomeDay (10-20-2017)
I just installed one with the power duct on my 2001 it was a bear getting it all to fit and line up. I was not able to install the MAF by the filter like the video shows, no way it was going to fit there. I ended up installing the MAF up by the TB. I also didn't use the pieces that mate the ducts to the grill area where the fog lights are, I ended up using my stock ones and made a cut out to accept the ducts matching the ones in the kit. The ones that come with the kit have no tab on the outside end and there was no way the duct was going to line up w/o the bolt in that tab at the end. I also found it was VERY difficult to get the MAF out of the stock air bridge, I finally got it out by prying with a really big screw driver and then twisting it the rest of the way out slowly. Good luck with your install, it's pretty frustrating getting it in but when you do you will really like it. I also think you will need a tune, my car is running really rich at WOT now. I can post some pictures to help if you need them.
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Haven't been on here in quite some time but wow, my instructions are still valid and wanted?
I just popped on here tonight looking for a manual torque tube and ran across this. I'm still dealing with hurricane issues but will try and put up those and the other instructions I had back up soon if they help. I figure there would be much better ones since mine were from the early 2000's...
VaraRam Industries (11-08-2017)
Best of luck
Jim
