Bumpstop replacement help
Old Oct 20, 2017 | 01:44 PM
Golfingbob's Avatar
Golfingbob
Default Bumpstop replacement help
Just got my bumpstops from Rodney Dickman. I have a 2002 coupe. The headlight sometimes will not raise. I see 2 stops when I raise the hood. Will the headlight need to be removed to change the lower 2. Tried to find a video showing how to replace but could not find one that showed the lower 2 that are attached to the motor. Thanks
Old Oct 20, 2017 | 03:10 PM
Moving to C5 Tech.
Old Oct 20, 2017 | 09:23 PM
luffy's Avatar
luffy
If you lower the headlights and look at the linkage from the back of the car, you will see the white bump stops that it sounds like you're missing
To Bumpstop replacement help
